Lenovo ThinkPad T14 Gen 3 Keyboard Replacement
  1. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 1 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 2 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disable battery: step 1, image 3 of 3
    • Start by disabling the internal battery in the BIOS.
    • You can enable the battery again by connecting the included power adapter.
    • If you choose to skip this step, make sure that the laptop is fully powered off before you start to avoid damaging anything.
  2. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Loosen the keyboard screws: step 2, image 1 of 1
    • Loosen the two screws holding the keyboard in place.
    • Note: These are captive screws that don't come out fully.
  3. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Slide keyboard up: step 3, image 1 of 1
    • Slide the keyboard up until the tabs at the bottom are free.
    • Try not to press any of the keys or it will be difficult to slide.
  4. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Lift out keyboard: step 4, image 3 of 3
    • Lift the bottom slightly and pull out from the frame.
    • Note: Be mindful of the fragile cables that are still attached.
    • Once you have it out, fold it down on the frame.
  5. Lenovo ThinkPad T14 Gen 3 Keyboard Replacement, Disconnect the keyboard cables: step 5, image 1 of 1
    • Using a spudger or your fingernail, carefully disconnect the two cables connecting the keyboard to the motherboard.
5 other people completed this guide.
Zachariah Orton
405 Reputation
1 Guide authored
One Comment
Danke
nun braucht man auch kein spezialwerkzeug mehr wie bei den alten T14
Thanks
now you don't need any special tools like with the old T14
Ingo Schneider - Reply
Past 24 Hours: 12
Past 7 Days: 62
Past 30 Days: 391
All Time: 7,054
