Lenovo IdeaPad Z570 Keyboard Replacement
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: step 2, image 1 of 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: step 3, image 1 of 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: step 4, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 4, image 2 of 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: step 5, image 1 of 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: step 6, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 6, image 2 of 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: step 7, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 7, image 2 of 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: step 8, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 8, image 2 of 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: step 9, image 1 of 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: step 9, image 2 of 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: step 9, image 3 of 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: step 10, image 1 of 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: step 11, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 11, image 2 of 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: step 12, image 1 of 3 Lenovo IdeaPad Z570 Keyboard Replacement: step 12, image 2 of 3 Lenovo IdeaPad Z570 Keyboard Replacement: step 12, image 3 of 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: step 13, image 1 of 2 Lenovo IdeaPad Z570 Keyboard Replacement: step 13, image 2 of 2
    • Pull the keyboard out from the terminal block.
2 other people completed this guide.
Mya DeSantos
318 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,162
