Lenovo IdeaPad S210 Touch Speaker Replacement
  1. Lenovo IdeaPad S210 Touch Speaker Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Speaker Replacement: step 2, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 2, image 2 of 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Speaker Replacement, Back Panel: step 3, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement, Back Panel: step 3, image 2 of 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Speaker Replacement: step 4, image 1 of 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Speaker Replacement: step 5, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 5, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 5, image 3 of 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Speaker Replacement, Wi-Fi Network Card: step 6, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement, Wi-Fi Network Card: step 6, image 2 of 2
    • Remove both antenna wires by pulling upwards gently.
  7. Lenovo IdeaPad S210 Touch Speaker Replacement: step 7, image 1 of 1
    • Using the #00 Phillips screwdriver, remove one 3mm screw from the network card.
  8. Lenovo IdeaPad S210 Touch Speaker Replacement: step 8, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 8, image 2 of 2
    • Slide Wi-Fi network card away from motherboard and remove gently.
  9. Lenovo IdeaPad S210 Touch Speaker Replacement, Hard Drive: step 9, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement, Hard Drive: step 9, image 2 of 2
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  10. Lenovo IdeaPad S210 Touch Speaker Replacement: step 10, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 10, image 2 of 2
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  11. Lenovo IdeaPad S210 Touch Speaker Replacement: step 11, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 11, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 11, image 3 of 3
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
  12. Lenovo IdeaPad S210 Touch Speaker Replacement, Cooling Fan: step 12, image 1 of 1
    • Many of the wire connections to the motherboard are secured by tape for vibration protection. Your device may or may not have this tape.
    • If any tape is present, remove all tape from the area within the red area.
  13. Lenovo IdeaPad S210 Touch Speaker Replacement: step 13, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 13, image 2 of 2
    • Using a #0 Phillips screwdriver, unscrew the four 3mm captive screws securing the copper tube onto the motherboard.
    • These captive screws are secured by plastic washer to the copper tube and will remain in the heat sink assembly during removal.
  14. Lenovo IdeaPad S210 Touch Speaker Replacement: step 14, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 14, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 14, image 3 of 3
    • Remove the tape connecting the copper tubing to the cooling fan.
    • Lift and remove the heat sink assembly.
  15. Lenovo IdeaPad S210 Touch Speaker Replacement: step 15, image 1 of 1
    • Using a #0 Phillips screwdriver, remove the three 3mm screws around the perimeter of the fan.
  16. Lenovo IdeaPad S210 Touch Speaker Replacement: step 16, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 16, image 2 of 2
    • Remove the wiring from the motherboard by gently pulling the wire connector at the base of the wires.
    • Once the wires are removed, the cooling fan assembly is disconnected. You may now remove the cooling fan.
  17. Lenovo IdeaPad S210 Touch Speaker Replacement, Motherboard: step 17, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement, Motherboard: step 17, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement, Motherboard: step 17, image 3 of 3
    • Your device may or may not have tape securing wired connections. If it is present, it must be removed before disconnecting cabling.
    • Remove four cables connected to motherboard by pulling gently on connector at base of cables.
  18. Lenovo IdeaPad S210 Touch Speaker Replacement: step 18, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 18, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 18, image 3 of 3
    • Use a spudger to lift the connector lock to the small ribbon cable attached near where the cooling fan was located.
    • After unlocking the connector, gently pull the removal tab on the ribbon cable to remove completely.
  19. Lenovo IdeaPad S210 Touch Speaker Replacement: step 19, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 19, image 2 of 2
    • Using a #0 Phillips screwdriver, remove the seven 3mm screws securing the motherboard to the chassis.
  20. Lenovo IdeaPad S210 Touch Speaker Replacement: step 20, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement: step 20, image 2 of 2
    • Slowly tilt the motherboard forward so you can access the bottom.
  21. Lenovo IdeaPad S210 Touch Speaker Replacement: step 21, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 21, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 21, image 3 of 3
    • Using a spudger, remove the smaller of the two ribbon cables by lifting on the black connector.
    • Once connector is lifted, gently pull on the ribbon cable to remove it.
  22. Lenovo IdeaPad S210 Touch Speaker Replacement: step 22, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 22, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 22, image 3 of 3
    • Remove the second (and last) ribbon cable from the motherboard by gently pulling on the blue pull tab.
    • Lift and remove motherboard from laptop chassis.
  23. Lenovo IdeaPad S210 Touch Speaker Replacement, Speaker: step 23, image 1 of 2 Lenovo IdeaPad S210 Touch Speaker Replacement, Speaker: step 23, image 2 of 2
    • Using a #00 Phillips screwdriver, remove four 1mm screws from the two speakers.
  24. Lenovo IdeaPad S210 Touch Speaker Replacement: step 24, image 1 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 24, image 2 of 3 Lenovo IdeaPad S210 Touch Speaker Replacement: step 24, image 3 of 3
    • Separate the wires from the chassis and lift to remove the speakers.
Zack Colman
885 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 173
