Lenovo IdeaPad S210 Touch Cooling Fan Replacement
  1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 2, image 1 of 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 2, image 2 of 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: step 3, image 1 of 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: step 3, image 2 of 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 4, image 1 of 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 5, image 1 of 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 5, image 2 of 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 5, image 3 of 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Cooling Fan: step 6, image 1 of 1
    • Many of the wire connections to the motherboard are secured by tape for vibration protection. Your device may or may not have this tape.
    • If any tape is present, remove all tape from the area within the red area.
  7. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 7, image 1 of 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 7, image 2 of 2
    • Using a #0 Phillips screwdriver, unscrew the four 3mm captive screws securing the copper tube onto the motherboard.
    • These captive screws are secured by plastic washer to the copper tube and will remain in the heat sink assembly during removal.
  8. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 8, image 1 of 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 8, image 2 of 3 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 8, image 3 of 3
    • Remove the tape connecting the copper tubing to the cooling fan.
    • Lift and remove the heat sink assembly.
  9. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 9, image 1 of 1
    • Using a #0 Phillips screwdriver, remove the three 3mm screws around the perimeter of the fan.
  10. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 10, image 1 of 2 Lenovo IdeaPad S210 Touch Cooling Fan Replacement: step 10, image 2 of 2
    • Remove the wiring from the motherboard by gently pulling the wire connector at the base of the wires.
    • Once the wires are removed, the cooling fan assembly is disconnected. You may now remove the cooling fan.
Zack Colman
885 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 635
