Lenovo IdeaPad S210 Touch Back Panel Replacement
  1. Lenovo IdeaPad S210 Touch Back Panel Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Back Panel Replacement: step 2, image 1 of 2 Lenovo IdeaPad S210 Touch Back Panel Replacement: step 2, image 2 of 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: step 3, image 1 of 2 Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: step 3, image 2 of 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Back Panel Replacement: step 4, image 1 of 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Back Panel Replacement: step 5, image 1 of 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: step 5, image 2 of 3 Lenovo IdeaPad S210 Touch Back Panel Replacement: step 5, image 3 of 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Zack Colman
885 Reputation
8 Guides authored
One Comment
Witam ile zatok część chce pan
Mikolaj Dabrowski - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 555
