Lenovo IdeaPad Flex 6-14IKB Speakers Replacement
  1. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Base Cover: step 1, image 1 of 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: step 3, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the wire connector from the speaker using the tweezers.
  4. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: step 4, image 2 of 2
    • Lift the right side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
  5. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: step 5, image 1 of 1
    • Unwind the red and black wire that connects the two speakers from the plastic clips that secure it.
  6. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: step 6, image 1 of 1
    • Lift the left side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 111
