Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement
  1. Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 2, image 3 of 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 3, image 1 of 1
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement, Battery: step 4, image 1 of 2 Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5 14ARE05 Battery Replacement: step 5, image 2 of 2
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
3 other people completed this guide.
Tyler Schrock
401 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 138
All Time: 6,249
