Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement
  1. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: step 2, image 3 of 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: step 3, image 1 of 1
    • Once all the clips have been disengaged, lift off the back cover.
4 other people completed this guide.
Tyler Schrock
401 Reputation
2 Guides authored
3 Comments
This guide has been very helpful but I have a problem with missing screws 3 have fallen out now. and I see the guide doesn't list any parts so where could I go to find the screws?
Timothy Alper - Reply
Same issue (on a Lenovo ChromeBook Flex 5 ‎82B80006UX). I'm guessing a M2 or M2.5 x 5mm & 8mm. I'm ordering some assorted screws & I'll post if any seem to really hit the size.
BenBen7 -
Hi. Why do some laptops have some kind of a sheet of paper blocking some part of their bottom vents, leaving a hole only for the fan intake? Is it safe to remove the paper?
Haris Sahlan - Reply
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 79
All Time: 2,154
