Lenovo IdeaPad 110-15ISK Optical Drive Replacement
  1. Lenovo IdeaPad 110-15ISK Optical Drive Replacement, Keyboard: step 1, image 1 of 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Optical Drive Replacement: step 2, image 1 of 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Optical Drive Replacement: step 3, image 1 of 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Optical Drive Replacement, Optical Drive: step 5, image 1 of 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Optical Drive Replacement: step 6, image 1 of 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
Tyler
597 Reputation
3 Guides authored
UW Tacoma, Team S1-G5, Rose Fall 2018 Member of UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 Members
39 Guides authored
One Comment
Hi, I have an Lenovo ideapad 110-15isk laptop. The size of the optical drive is 9.0 mm. Can I trace the 9.5 mm specimens ??because there is no 9.0 mimeter available now?  Thanks s lot.
Ali Mohammadi - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 2,081
