Lenovo IdeaPad 110-15ISK Hard Drive Replacement
  1. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Back Keyboard Screws: step 1, image 1 of 1
    • Remove the two keyboard screws on the back of the device(the two on the same row)
  2. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Remove the Keyboard: step 2, image 1 of 1
    • Insert a prying tool in the crack between the keyboard and frame. Start by the power button and go all the way round the keyboard.
  3. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Keyboard Ribbon Cable: step 3, image 1 of 1
    • Remover the ribbon cable and remove the keyboard afterward.
  4. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Under Keyboard: step 4, image 1 of 1
    • After the keyboard is removed, remove the screw and the battery connector.
  5. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Disk Drive: step 5, image 1 of 1
    • Remove the screw that is under the two keyboard screws and pull the disk drive out.
  6. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Outer Screws: step 6, image 1 of 1
    • Remove all of the screws on the outside edge of the bottom.
  7. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Separating the Case: step 7, image 1 of 1
    • Flip the laptop over and in the crack between the two case pieces slide a prying tool in between and follow the perimeter until the two pieces are separated.
  8. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Drive Bay: step 8, image 1 of 1
    • Remove the four screws securing the drive bay into the case.
  9. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Removing the Drive: step 9, image 1 of 1
    • Remove the four screws the hold the metal cage onto the drive to separate them.
Stuart Luhigo
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 531
