Lenovo IdeaPad 100s-14IBR Battery Replacement
  1. Lenovo IdeaPad 100s-14IBR Battery Replacement, Battery: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: step 2, image 2 of 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Battery Replacement: step 3, image 1 of 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: step 3, image 2 of 2
    • Remove six 4mm Phillips #00 screws.
    • Pull the battery connector parallel to the motherboard to disconnect the battery from the motherboard.
  4. Lenovo IdeaPad 100s-14IBR Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: step 4, image 2 of 2
    • Use a nylon spudger to pry the battery up and out of the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 47
All Time: 4,193
