Lenovo IdeaCentre K410 Power Supply Unit Replacement
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: step 1, image 1 of 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 2, image 1 of 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: step 3, image 1 of 2 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: step 3, image 2 of 2
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 4, image 1 of 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 4, image 2 of 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 4, image 3 of 3
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 5, image 1 of 1
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: step 6, image 1 of 1
    • Remove the power supply unit by pulling away from the screw side and then out.
9 other people completed this guide.
Timothy Grebe
1,634 Reputation
9 Guides authored
Cal Poly, Team 10-39, Amido Fall 2014 Member of Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Members
18 Guides authored
One Comment
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 4,355
