Lenovo Flex 6-11IGM Trackpad Replacement
  1. Lenovo Flex 6-11IGM Trackpad Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Trackpad Replacement: step 2, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement: step 2, image 2 of 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Trackpad Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Trackpad Replacement: step 4, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement: step 4, image 2 of 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Trackpad Replacement, Battery: step 5, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement, Battery: step 5, image 2 of 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Trackpad Replacement: step 6, image 1 of 3 Lenovo Flex 6-11IGM Trackpad Replacement: step 6, image 2 of 3 Lenovo Flex 6-11IGM Trackpad Replacement: step 6, image 3 of 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Trackpad Replacement: step 7, image 1 of 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: step 8, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: step 8, image 2 of 2
    • Remove the connecting wire labelled "TP" by lifting the tab with the opening tool.
  9. Lenovo Flex 6-11IGM Trackpad Replacement: step 9, image 1 of 3 Lenovo Flex 6-11IGM Trackpad Replacement: step 9, image 2 of 3 Lenovo Flex 6-11IGM Trackpad Replacement: step 9, image 3 of 3
    • Disconnect the keyboard ribbon from the motherboard by lifting the black tab and pulling the ribbon out with the opening tool.
  10. Lenovo Flex 6-11IGM Trackpad Replacement: step 10, image 1 of 1
    • Pull up the black safety tape.
  11. Lenovo Flex 6-11IGM Trackpad Replacement: step 11, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement: step 11, image 2 of 2
    • Remove the three silver 2.3 mm Phillips #00 screws.
    • The third one is under the black tape.
  12. Lenovo Flex 6-11IGM Trackpad Replacement: step 12, image 1 of 2 Lenovo Flex 6-11IGM Trackpad Replacement: step 12, image 2 of 2
    • Slide the trackpad up from its seat using the opening tool and remove it.
Rie Kuraoka
886 Reputation
7 Guides authored
Cal Poly, Team S7-G10, Paton Spring 2020 Member of Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 318
