Lenovo Flex 6-11IGM Heat Sink Replacement
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: step 2, image 1 of 2 Lenovo Flex 6-11IGM Heat Sink Replacement: step 2, image 2 of 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: step 4, image 1 of 2 Lenovo Flex 6-11IGM Heat Sink Replacement: step 4, image 2 of 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: step 5, image 1 of 2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: step 5, image 2 of 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: step 6, image 1 of 3 Lenovo Flex 6-11IGM Heat Sink Replacement: step 6, image 2 of 3 Lenovo Flex 6-11IGM Heat Sink Replacement: step 6, image 3 of 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: step 7, image 1 of 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: step 8, image 1 of 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: step 8, image 2 of 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: step 8, image 3 of 3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: step 9, image 1 of 2 Lenovo Flex 6-11IGM Heat Sink Replacement: step 9, image 2 of 2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Rie Kuraoka
886 Reputation
7 Guides authored
Cal Poly, Team S7-G10, Paton Spring 2020 Member of Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 294
