Lenovo Flex 6-11IGM Battery Replacement
  1. Lenovo Flex 6-11IGM Battery Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Battery Replacement: step 2, image 1 of 2 Lenovo Flex 6-11IGM Battery Replacement: step 2, image 2 of 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Battery Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Battery Replacement: step 4, image 1 of 2 Lenovo Flex 6-11IGM Battery Replacement: step 4, image 2 of 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Battery Replacement, Battery: step 5, image 1 of 2 Lenovo Flex 6-11IGM Battery Replacement, Battery: step 5, image 2 of 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Battery Replacement: step 6, image 1 of 3 Lenovo Flex 6-11IGM Battery Replacement: step 6, image 2 of 3 Lenovo Flex 6-11IGM Battery Replacement: step 6, image 3 of 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Battery Replacement: step 7, image 1 of 1
    • Remove the now disconnected battery from the laptop.
Dustin Healy
241 Reputation
2 Guides authored
Cal Poly, Team S2-G4, White Winter 2020 Member of Cal Poly, Team S2-G4, White Winter 2020
CPSU-WHITE-W20S2G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,369
