Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: step 1, image 1 of 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 2, image 1 of 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 2, image 2 of 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 4, image 1 of 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 4, image 2 of 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: step 5, image 1 of 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: step 5, image 2 of 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: step 5, image 3 of 3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 6, image 1 of 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: step 6, image 2 of 2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
Rie Kuraoka
886 Reputation
7 Guides authored
Cal Poly, Team S7-G10, Paton Spring 2020 Member of Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 374
