Lasko 2002W Motor Replacement
  1. Lasko 2002W Motor Replacement, Remove cover: step 1, image 1 of 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: step 2, image 1 of 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: step 3, image 1 of 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: step 4, image 1 of 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: step 5, image 1 of 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
9 other people completed this guide.
elsa
382 Reputation
1 Guide authored
USF Tampa, Team 1-39, Donnelly Fall 2014 Member of USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Member
1 Guide authored
One Comment
What is the part number for replacement motor? Where do you get it?
Paul Dias - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 49
All Time: 3,559
