Introduction
If your Land Yachtz longboard isn't turning well or you find that you can't adjust the tension of your trucks, your board kingpin may be damaged or faulty. Use this guide to replace the faulty kingpin and get your board back into good shape.
The kingpin is essential in turning the board with your body weight and allowing the user to effectively control their movement. If it is faulty, the board will not do its job and injury can result.
This ten-step guide will show you how to replace the kingpin without potentially damaging other parts of the longboard and allow for a better ride.
Use a 3/8" socket wrench, adjustable wrench, or skate tool to take off all 4 of the screws holding the truck to the board.
Test out your longboard and make sure that you can tighten and loosen the trucks effectively. Take it for a ride and make sure that turning works as you expect it to. If the problem persists, double-check to make sure that everything is put on correctly and the nuts are all securely fastened.
