LG VX8550 Speaker Replacement
  1. LG VX8550 Speaker Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release up.
  2. LG VX8550 Speaker Replacement: step 2, image 1 of 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Speaker Replacement, Case: step 3, image 1 of 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Speaker Replacement: step 4, image 1 of 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Speaker Replacement: step 5, image 1 of 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Speaker Replacement: step 6, image 1 of 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Speaker Replacement: step 7, image 1 of 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Speaker Replacement, Speaker: step 8, image 1 of 1
    • With the back casing removed the speaker is visible.
  9. LG VX8550 Speaker Replacement: step 9, image 1 of 1
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  10. LG VX8550 Speaker Replacement: step 10, image 1 of 1
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  11. LG VX8550 Speaker Replacement: step 11, image 1 of 1
    • Carefully unplug speaker connector from circuit board with your fingers.
  12. LG VX8550 Speaker Replacement: step 12, image 1 of 1
    • Remove the speaker by lifting up.
Nathan Jones
89 Reputation
10 Guides authored
Cal Poly, Team 34-55, Forte Spring 2010 Member of Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 2,017
