LG VX5500 Audio Port Replacement
  1. LG VX5500 Audio Port Replacement, Battery: step 1, image 1 of 3 LG VX5500 Audio Port Replacement, Battery: step 1, image 2 of 3 LG VX5500 Audio Port Replacement, Battery: step 1, image 3 of 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Audio Port Replacement, Audio Port: step 2, image 1 of 2 LG VX5500 Audio Port Replacement, Audio Port: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Audio Port Replacement: step 3, image 1 of 3 LG VX5500 Audio Port Replacement: step 3, image 2 of 3 LG VX5500 Audio Port Replacement: step 3, image 3 of 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Audio Port Replacement: step 4, image 1 of 2 LG VX5500 Audio Port Replacement: step 4, image 2 of 2
    • Locate the audio port; this is what it should look like.
    • The audio port is mounted and connected at 6 points. Check the integrity of these connections.
    • If any of the connections are dislodged or the audio port is damaged, desolder the port and install a new one.
2 other people completed this guide.
Kurt Beske
70 Reputation
1 Guide authored
Cal Poly, Team 7-33, Maness Spring 2012 Member of Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 446
