LG VX5400 Logic Board Replacement
  1. LG VX5400 Logic Board Replacement, Battery: step 1, image 1 of 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Logic Board Replacement: step 2, image 1 of 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Logic Board Replacement: step 3, image 1 of 3 LG VX5400 Logic Board Replacement: step 3, image 2 of 3 LG VX5400 Logic Board Replacement: step 3, image 3 of 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Logic Board Replacement, Outer Casing: step 4, image 1 of 1
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Logic Board Replacement: step 5, image 1 of 1
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Logic Board Replacement, Logic Board: step 6, image 1 of 2 LG VX5400 Logic Board Replacement, Logic Board: step 6, image 2 of 2
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  7. LG VX5400 Logic Board Replacement: step 7, image 1 of 2 LG VX5400 Logic Board Replacement: step 7, image 2 of 2
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
2 other people completed this guide.
Sourabh
132 Reputation
3 Guides authored
Cal Poly, Team 26-26, Regan Spring 2010 Member of Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 2,495
