LG Optimus L90 Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. LG Optimus L90 Motherboard Replacement, Battery: step 1, image 1 of 3 LG Optimus L90 Motherboard Replacement, Battery: step 1, image 2 of 3 LG Optimus L90 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Carefully slide an opening pick between the the rear cover and the body of the phone.
    • Using the pick, separate the cover from the back of the phone.
    • Remove the rear cover.
  2. LG Optimus L90 Motherboard Replacement: step 2, image 1 of 2 LG Optimus L90 Motherboard Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool int o the small recess at the bottom of the battery.
    • Use the plastic opening tool to lift up the bottom of the battery.
    • Remove the battery from the phone.
  3. LG Optimus L90 Motherboard Replacement, Motherboard: step 3, image 1 of 2 LG Optimus L90 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the eleven JIS #000 screws securing the midframe to the phone.
  4. LG Optimus L90 Motherboard Replacement: step 4, image 1 of 3 LG Optimus L90 Motherboard Replacement: step 4, image 2 of 3 LG Optimus L90 Motherboard Replacement: step 4, image 3 of 3
    • Using an opening pick, carefully separate the midframe from the motherboard.
  5. LG Optimus L90 Motherboard Replacement: step 5, image 1 of 3 LG Optimus L90 Motherboard Replacement: step 5, image 2 of 3 LG Optimus L90 Motherboard Replacement: step 5, image 3 of 3
    • Disconnect the flex cables (gold tags with prongs) from the motherboard.
  6. LG Optimus L90 Motherboard Replacement: step 6, image 1 of 2 LG Optimus L90 Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the thin black cable in the bottom-right corner of the phone.
  7. LG Optimus L90 Motherboard Replacement: step 7, image 1 of 3 LG Optimus L90 Motherboard Replacement: step 7, image 2 of 3 LG Optimus L90 Motherboard Replacement: step 7, image 3 of 3
    • Gently pry the motherboard away from the phone.
5 other people completed this guide.
Alex Arruda
511 Reputation
5 Guides authored
One Comment
excelente, ideia de aos iniciantes
adriano - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,324
