LG Optimus F3 Headphone Jack Replacement
  1. LG Optimus F3 Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 1
    • Place your thumb at the bottom of the phone's back where the charging port is located.
    • Gently pull the cover off.
  2. LG Optimus F3 Headphone Jack Replacement: step 2, image 1 of 1
    • Using the indent at the bottom of the battery, lift and remove the battery from the phone.
    • Place the battery in a safe location as you will need it for reassembly.
  3. LG Optimus F3 Headphone Jack Replacement: step 3, image 1 of 1
    • Remove the ten 1.0 mm screws on the rear case.
    • Place the screws in a safe location as you will need them for reassembly.
  4. LG Optimus F3 Headphone Jack Replacement: step 4, image 1 of 1
    • Pry apart the joints to separate the inner case.
    • Insert the opening tool on different locations until the case comes off easily.
    • To avoid damaging the joints of the case do not pry if there is resistance.
  5. LG Optimus F3 Headphone Jack Replacement: step 5, image 1 of 1
    • With the inner cover removed, locate your headphone jack.
    • It will be in the upper right corner on the back of the phone.
  6. LG Optimus F3 Headphone Jack Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Gently grab the headphone jack along the sides with tweezers.
    • Lift the headphone jack out of its socket.
  7. LG Optimus F3 Headphone Jack Replacement: step 7, image 1 of 1
    • Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
    • Make sure the dark side without the connectors is face up.
To reassemble your device follow these steps in reverse order.
4 other people completed this guide.
Ryan McDermott
324 Reputation
2 Guides authored
UMass Dartmouth, Team 1-5, Miles Fall 2015 Member of UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 538
