LG Muziq LX570 Front Case Replacement
  1. LG Muziq LX570 Front Case Replacement, Front Case: step 1, image 1 of 2 LG Muziq LX570 Front Case Replacement, Front Case: step 1, image 2 of 2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: step 2, image 1 of 3 LG Muziq LX570 Front Case Replacement: step 2, image 2 of 3 LG Muziq LX570 Front Case Replacement: step 2, image 3 of 3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: step 3, image 1 of 3 LG Muziq LX570 Front Case Replacement: step 3, image 2 of 3 LG Muziq LX570 Front Case Replacement: step 3, image 3 of 3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
Raymond Ching
1 Reputation
1 Guide authored
Cal Poly, Team 3-29, Amido Winter 2012 Member of Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 585
