LG LX150 Battery Replacement
  1. LG LX150 Battery Replacement, Back Cover: step 1, image 1 of 3 LG LX150 Battery Replacement, Back Cover: step 1, image 2 of 3 LG LX150 Battery Replacement, Back Cover: step 1, image 3 of 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Battery Replacement, Battery: step 2, image 1 of 2 LG LX150 Battery Replacement, Battery: step 2, image 2 of 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Battery Replacement: step 3, image 1 of 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Andrea
110 Reputation
4 Guides authored
Cal Poly, Team 10-44, Garner Spring 2010 Member of Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,428
