LG G2 mini LTE Rear Facing Camera Replacement
  1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery Cover: step 1, image 1 of 1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery: step 2, image 1 of 1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: step 3, image 1 of 2 LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: step 3, image 2 of 2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Motherboard Cover: step 4, image 1 of 1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: step 5, image 1 of 3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: step 5, image 2 of 3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: step 5, image 3 of 3
    • Locate the rear facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool.
    • Use your finger to remove the camera.
2 other people completed this guide.
Nicholas Van Beek
581 Reputation
1 Guide authored
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,660
