LG Cosmos Motherboard Replacement
  1. LG Cosmos Motherboard Replacement, Battery: step 1, image 1 of 1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Motherboard Replacement: step 2, image 1 of 1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Motherboard Replacement, Rear Case: step 3, image 1 of 1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Motherboard Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Motherboard Replacement: step 5, image 1 of 1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Motherboard Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Motherboard Replacement: step 8, image 1 of 1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Motherboard Replacement: step 9, image 1 of 1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Motherboard Replacement: step 10, image 1 of 1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Motherboard Replacement: step 11, image 1 of 1
    • Pull the motherboard away from the rest of the phone.
Johnny Phane
70 Reputation
5 Guides authored
Cal Poly, Team 13-63, Johann Spring 2013 Member of Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,874
