Kurio Touch 4S Speaker Replacement
  1. Kurio Touch 4S Speaker  Replacement, Speakers: step 1, image 1 of 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: step 2, image 1 of 3 Kurio Touch 4S Speaker  Replacement: step 2, image 2 of 3 Kurio Touch 4S Speaker  Replacement: step 2, image 3 of 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: step 3, image 1 of 2 Kurio Touch 4S Speaker  Replacement: step 3, image 2 of 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: step 4, image 1 of 1
  5. Kurio Touch 4S Speaker  Replacement: step 5, image 1 of 1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: step 6, image 1 of 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: step 7, image 1 of 1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: step 8, image 1 of 1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Moin Khan
234 Reputation
2 Guides authored
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 172
