Kurio Touch 4S Battery Replacement
  1. Kurio Touch 4S Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: step 2, image 1 of 3 Kurio Touch 4S Battery Replacement: step 2, image 2 of 3 Kurio Touch 4S Battery Replacement: step 2, image 3 of 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: step 3, image 1 of 3 Kurio Touch 4S Battery Replacement: step 3, image 2 of 3 Kurio Touch 4S Battery Replacement: step 3, image 3 of 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: step 4, image 1 of 1
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: step 6, image 1 of 1
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
3 other people completed this guide.
Khalid AlTamimi
275 Reputation
2 Guides authored
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Members
10 Guides authored
2 Comments
do you know where to buy a replacement battery ?
Phil Bowring - Reply
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - Reply
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,614
