Koss Porta Pro Speaker Holder Replacement
  1. Koss Porta Pro Speaker Holder Replacement, Remove cushion: step 1, image 1 of 3 Koss Porta Pro Speaker Holder Replacement, Remove cushion: step 1, image 2 of 3 Koss Porta Pro Speaker Holder Replacement, Remove cushion: step 1, image 3 of 3
    • Remove cushion using knife.
  2. Koss Porta Pro Speaker Holder Replacement, Remove comfortZone label: step 2, image 1 of 2 Koss Porta Pro Speaker Holder Replacement, Remove comfortZone label: step 2, image 2 of 2
    • Remove label using flat screwdriver.
  3. Koss Porta Pro Speaker Holder Replacement, Remove clip: step 3, image 1 of 3 Koss Porta Pro Speaker Holder Replacement, Remove clip: step 3, image 2 of 3 Koss Porta Pro Speaker Holder Replacement, Remove clip: step 3, image 3 of 3
    • Use screwdriver to start bending edges of clip.
    • Continue bending with pliers or cutters.
    • Push clip with screwdriver and pull with cutters from another side.
    • This step can take up to 15 minutes, so keep calm and continue bending.
  4. Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: step 4, image 1 of 3 Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: step 4, image 2 of 3 Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: step 4, image 3 of 3
    • Press tenon using screwdriver to remove shield.
    • Remove hoop from hoop holder.
  5. Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: step 5, image 1 of 3 Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: step 5, image 2 of 3 Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: step 5, image 3 of 3
    • Place hoop in hoop holer.
    • Close hoop holder with shield.
    • Insert M2.5x8 screw into hole and tighten the nut.
  6. Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: step 6, image 1 of 3 Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: step 6, image 2 of 3 Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: step 6, image 3 of 3
    • Stick comfortZone label over the screw. Use double-sided foam tape if head of screw is too high.
    • Stick cushion. Use additional double-sided tape if cushion has bad holding.
Left and right sides are the same so you can use this guide for both.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 1,933
