Kodak Easyshare P712 Memory Card Replacement
  1. Kodak Easyshare P712 Memory Card Replacement, Power Camera Off: step 1, image 1 of 1
    • Turn off the camera by turning the selector dial to “off.” This is located on top of the camera body.
  2. Kodak Easyshare P712 Memory Card Replacement, Open Door: step 2, image 1 of 1
    • Locate memory compartment on the side of the camera body and slide open by applying pressure in the direction of the arrow. Door will spring open.
  3. Kodak Easyshare P712 Memory Card Replacement, Insert/Remove Memory Card: step 3, image 1 of 3 Kodak Easyshare P712 Memory Card Replacement, Insert/Remove Memory Card: step 3, image 2 of 3 Kodak Easyshare P712 Memory Card Replacement, Insert/Remove Memory Card: step 3, image 3 of 3
    • Insert memory card (SD card) with the gold terminals facing downward. Gently press down until into you feel it lock into place. Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it out. Close memory compartment door.
Melanie Martin
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 206
