Kodak EasyShare V570 Jammed Shutter Button Fix
  1. Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: step 1, image 1 of 3 Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: step 1, image 2 of 3 Kodak EasyShare V570 Jammed Shutter Button Fix, Kodak EasyShare V570 Jammed Shutter Button Fix: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Make sure that the tools are acquired, The 70% Isopropyl Alcohol and Q-tips are needed, but if the tweezers are not available that is okay. Fingernails or a credit card are just fine. Anything that can move the button without damaging it works.
  2. Kodak EasyShare V570 Jammed Shutter Button Fix: step 2, image 1 of 3 Kodak EasyShare V570 Jammed Shutter Button Fix: step 2, image 2 of 3 Kodak EasyShare V570 Jammed Shutter Button Fix: step 2, image 3 of 3
    • Pour a little bit of the alcohol into the cap
    • Take the Q-tip and sink the cotton end into the cap
    • Move the Q-tip onto the Shutter Button and move it around in circular motions
    • While the alcohol is still wet use the choice of tool and try to wiggle the button back and forth
    • After the button is wiggled a couple of times, try and see if the button is able to be pushed down.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 56
