Kodak EasyShare M2008 Battery Door Replacement
  1. Kodak EasyShare M2008 Battery Door Replacement, Battery: step 1, image 1 of 2 Kodak EasyShare M2008 Battery Door Replacement, Battery: step 1, image 2 of 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Battery Door Replacement: step 2, image 1 of 2 Kodak EasyShare M2008 Battery Door Replacement: step 2, image 2 of 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Battery Door Replacement, Device Casing: step 3, image 1 of 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: step 3, image 2 of 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: step 3, image 3 of 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Battery Door Replacement: step 4, image 1 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 4, image 2 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 4, image 3 of 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Battery Door Replacement: step 5, image 1 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 5, image 2 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 5, image 3 of 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Battery Door Replacement, Battery Door: step 6, image 1 of 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: step 6, image 2 of 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  7. Kodak EasyShare M2008 Battery Door Replacement: step 7, image 1 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 7, image 2 of 3 Kodak EasyShare M2008 Battery Door Replacement: step 7, image 3 of 3
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  8. Kodak EasyShare M2008 Battery Door Replacement: step 8, image 1 of 2 Kodak EasyShare M2008 Battery Door Replacement: step 8, image 2 of 2
    • Gently lift off door cover.
Kyanna
313 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 169
