Kobold VK150 Wiring Harness Replacement
  1. Kobold VK150 Wiring Harness Replacement, Remove screws from housing: step 1, image 1 of 2 Kobold VK150 Wiring Harness Replacement, Remove screws from housing: step 1, image 2 of 2
    • Use a TX10 screwdriver
    • Remove the housing screws on the rear of the device.
    • 6 long screws
    • 3 short screws
  2. Kobold VK150 Wiring Harness Replacement, Remove housing cover: step 2, image 1 of 1
    • Place the device with the white lid facing up.
    • Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
    • At the top of the stem, a small plastic part holds in the gray casing of the suction cup!
  3. Kobold VK150 Wiring Harness Replacement, Separate parts: step 3, image 1 of 1
    • Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
  4. Kobold VK150 Wiring Harness Replacement, Remove the plug: step 4, image 1 of 2 Kobold VK150 Wiring Harness Replacement, Remove the plug: step 4, image 2 of 2
    • Disconnect the power supply connector by pressing the unlocking lever.
    • Unplug the motherboard connector.
    • Put the cable aside
  5. Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: step 5, image 1 of 3 Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: step 5, image 2 of 3 Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: step 5, image 3 of 3
    • Unlock and loosen the rotary switch plug.
    • Disconnect the white air hose from the intake manifold.
    • Release 2 plastic clips
    • Remove the wiring harness with the plastic holder.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Lukas Fritz
362 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 1,301
