Kobold VK150 Motor Change
  1. Kobold VK150 Motor Change, Remove screws from housing: step 1, image 1 of 2 Kobold VK150 Motor Change, Remove screws from housing: step 1, image 2 of 2
    • Use a TX10 screwdriver
    • Remove the housing screws on the rear of the device.
    • 6 long screws
    • 3 short screws
  2. Kobold VK150 Motor Change, Remove housing cover: step 2, image 1 of 1
    • Place the device with the white lid facing up.
    • Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
    • At the top of the stem, a small plastic part holds in the gray casing of the suction cup!
  3. Kobold VK150 Motor Change, Separate parts: step 3, image 1 of 1
    • Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
  4. Kobold VK150 Motor Change, Remove the plug: step 4, image 1 of 2 Kobold VK150 Motor Change, Remove the plug: step 4, image 2 of 2
    • Disconnect the power supply connector by pressing the unlocking lever.
    • Unplug the motherboard connector.
    • Put the cable aside
  5. Kobold VK150 Motor Change, Remove the wiring harness: step 5, image 1 of 3 Kobold VK150 Motor Change, Remove the wiring harness: step 5, image 2 of 3 Kobold VK150 Motor Change, Remove the wiring harness: step 5, image 3 of 3
    • Unlock and loosen the rotary switch plug.
    • Disconnect the white air hose from the intake manifold.
    • Release 2 plastic clips
    • Remove the wiring harness with the plastic holder.
  6. Kobold VK150 Motor Change, Motor Removal: step 6, image 1 of 2 Kobold VK150 Motor Change, Motor Removal: step 6, image 2 of 2
    • Remove the motor and main board assembly from the housing.
    • Remove the foam
    • Be careful not to fray the holes in the foam
  7. Kobold VK150 Motor Change, Prepare motor (align shaft): step 7, image 1 of 3 Kobold VK150 Motor Change, Prepare motor (align shaft): step 7, image 2 of 3 Kobold VK150 Motor Change, Prepare motor (align shaft): step 7, image 3 of 3
    • Stand the motor with the main circuit board upright .
    • Align the motor shaft by turning it so that the lamella of the speedometer is in the area of ​​the orange square.
    • If the shaft is not properly aligned, there is a risk that the forked light barrier or the speedometer lamella can break. Focus on the images to understand the alignment
  8. Kobold VK150 Motor Change, Removal of the motor connector: step 8, image 1 of 3 Kobold VK150 Motor Change, Removal of the motor connector: step 8, image 2 of 3 Kobold VK150 Motor Change, Removal of the motor connector: step 8, image 3 of 3
    • Slightly push on the black plastic connector. The connector should come off easily
    • If the connector gets caught in the marked area, the motor shaft must be aligned as described in the previous step.
  9. Kobold VK150 Motor Change, Dismantle the motor mount: step 9, image 1 of 3 Kobold VK150 Motor Change, Dismantle the motor mount: step 9, image 2 of 3 Kobold VK150 Motor Change, Dismantle the motor mount: step 9, image 3 of 3
    • Use a levering tool to loosen the clips on the motor mount.
    • Top part o the motor casing can now be removed
    • The motor should now be exposed and ready to be removed. Mark the position of the old motor in order to fit the new motor properly. This will avoid later issues with the motor electrical connector.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Lukas Fritz
362 Reputation
3 Guides authored
6 Comments
Moin ! Ich habe das Problem das der Motor nach dem Tausch nur 5x klackert - er springt danach leider nicht mehr an. Hast du noch eine Idee?
Ich habe Motor + Platine getauscht.
Matthias Lüning - Reply
Hallo Ich hab das gleiche Problem, wie habt ihr das gelöst ?
Grüße Andrea
A. G.-H. -
Hallo, habe ebenfalls das "Summen und Klackern " nach dem Einschalten. Gibt es dazu vielleicht eine brauchbare Lösung? Im Elektronikforum beschreiben mehrere User dieses Symptom, wobei eine mögliche Abhilfe ein Austausch eines Eingangsspannungs Kondensator am Netzteil sein könnte?
Original Kommentar:
Vermutung:
Die Spannungsversorgung der Elektronik erfolgt über ein sog. Kondensatornetzteil, das heißt, ein Kondensator ist in Reihe mit der Netzspannung geschaltet und reduziert die Eingangsspannung für die Elektronik. Wenn dieser Kondensator Kapazität verliert, wird auch die Versorgungsspannung für die Elektronik zu niedrig.
Siegi - Reply
Hallo,
habe ebenso das Summen und Klacken (auf Stufe drei gut hörbar). Der Motor scheint anlaufen zu wollen, es macht aber den Eindruck das er klemmt. Gibt es bereits eine Lösung? Vielen Dank euch
Susi -
Moin, und Funktioniert es bei dir wider?
ich habe das gleiche Problem und komme noch nicht weiter.
Bilderhalter - Reply
Past 24 Hours: 3
Past 7 Days: 54
Past 30 Days: 243
All Time: 8,672
