Keurig Mini B-31 K-cup Holder Replacement
  1. Keurig Mini B-31 K-cup Holder Replacement, K-cup holder: step 1, image 1 of 1
    • Lift up the handle of the Keurig Mini.
  2. Keurig Mini B-31 K-cup Holder Replacement: step 2, image 1 of 2 Keurig Mini B-31 K-cup Holder Replacement: step 2, image 2 of 2
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
  3. Keurig Mini B-31 K-cup Holder Replacement: step 3, image 1 of 2 Keurig Mini B-31 K-cup Holder Replacement: step 3, image 2 of 2
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  4. Keurig Mini B-31 K-cup Holder Replacement: step 4, image 1 of 1
    • Pull the K-cup holder straight out.
7 other people completed this guide.
Andrew Adriance
1,914 Reputation
7 Guides authored
Cal Poly, Team 17-1, Forte Winter 2014 Member of Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Members
17 Guides authored
2 Comments
Press up on the outlet of the holder to push it out. This is covered in the manufacturer’s user manual which comes with the unit when new.
jastpeel - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 66
All Time: 12,808
