Keurig K70 Limit Switch Replacement
  1. Keurig K70 Limit Switch Replacement, Limit Switch: step 1, image 1 of 1
    • Open the K-Cup Holder by lifting the handle.
  2. Keurig K70 Limit Switch Replacement: step 2, image 1 of 1
    • While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
  3. Keurig K70 Limit Switch Replacement: step 3, image 1 of 3 Keurig K70 Limit Switch Replacement: step 3, image 2 of 3 Keurig K70 Limit Switch Replacement: step 3, image 3 of 3
    • Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
  4. Keurig K70 Limit Switch Replacement: step 4, image 1 of 2 Keurig K70 Limit Switch Replacement: step 4, image 2 of 2
    • Remove the two 10mm Phillips #1 screws from the switch.
  5. Keurig K70 Limit Switch Replacement: step 5, image 1 of 2 Keurig K70 Limit Switch Replacement: step 5, image 2 of 2
Kyle Maxwell
163 Reputation
1 Guide authored
Cal Poly, Team 20-4, Livingston Fall 2016 Member of Cal Poly, Team 20-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 2,342
