Keurig K40 Bottom Water Filter Replacement
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: step 1, image 1 of 2 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: step 1, image 2 of 2
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: step 2, image 1 of 2 Keurig K40 Bottom Water Filter Replacement: step 2, image 2 of 2
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: step 3, image 1 of 2 Keurig K40 Bottom Water Filter Replacement: step 3, image 2 of 2
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: step 4, image 1 of 1
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
12 other people completed this guide.
jonathan
738 Reputation
2 Guides authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
5 Guides authored
13 Comments
Where do you obtain a new filter?
Anthony Montoya - Reply
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - Reply
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - Reply
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - Reply
The answer seems to be: “You don’t.”
Van Davis - Reply
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 128
All Time: 34,518
