Keurig B70 Platinum Water Filter Replacement
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: step 1, image 1 of 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: step 1, image 2 of 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: step 1, image 3 of 3
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: step 2, image 1 of 3 Keurig B70 Platinum Water Filter Replacement: step 2, image 2 of 3 Keurig B70 Platinum Water Filter Replacement: step 2, image 3 of 3
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: step 3, image 1 of 3 Keurig B70 Platinum Water Filter Replacement: step 3, image 2 of 3 Keurig B70 Platinum Water Filter Replacement: step 3, image 3 of 3
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
Emily Ramirez
97 Reputation
1 Guide authored
UW Tacoma, Team S1-G6, Rose Fall 2018 Member of UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Members
5 Guides authored
4 Comments
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - Reply
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L -
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - Reply
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Dacaria L -
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 92
All Time: 10,459
