Keurig B70 Platinum Puncture Needle Replacement
  1. Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: step 1, image 1 of 3 Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: step 1, image 2 of 3 Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: step 1, image 3 of 3
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Keurig B70 Platinum Puncture Needle Replacement: step 2, image 1 of 2 Keurig B70 Platinum Puncture Needle Replacement: step 2, image 2 of 2
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Keurig B70 Platinum Puncture Needle Replacement: step 3, image 1 of 2 Keurig B70 Platinum Puncture Needle Replacement: step 3, image 2 of 2
    • Lift and pull the black plastic cover away from the Keurig.
  4. Keurig B70 Platinum Puncture Needle Replacement: step 4, image 1 of 1
    • Push the handle back and upward to detach it from the Keurig.
  5. Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: step 5, image 1 of 2 Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: step 5, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two 7.0 mm screws located on the sides of the tube near the puncture needle.
  6. Keurig B70 Platinum Puncture Needle Replacement: step 6, image 1 of 2 Keurig B70 Platinum Puncture Needle Replacement: step 6, image 2 of 2
    • Using both hands, pull the puncture needle tube and the Keurig tube apart to disconnect the tubes.
    • Don't be afraid to pull hard! The tubes are tightly connected.
  7. Keurig B70 Platinum Puncture Needle Replacement: step 7, image 1 of 2 Keurig B70 Platinum Puncture Needle Replacement: step 7, image 2 of 2
    • Slide the black plastic ring, which holds the puncture needle tube down, off of the tube.
  8. Keurig B70 Platinum Puncture Needle Replacement: step 8, image 1 of 3 Keurig B70 Platinum Puncture Needle Replacement: step 8, image 2 of 3 Keurig B70 Platinum Puncture Needle Replacement: step 8, image 3 of 3
    • Using a Phillips #2 screwdriver, remove the two 9.0 mm screws next to the detached tube.
    • Hold on to the puncture needle when removing the screws to ensure that the puncture needle does not fall and cause injury.
  9. Keurig B70 Platinum Puncture Needle Replacement: step 9, image 1 of 3 Keurig B70 Platinum Puncture Needle Replacement: step 9, image 2 of 3 Keurig B70 Platinum Puncture Needle Replacement: step 9, image 3 of 3
    • Gently pull the puncture needle down and out from the Keurig.
Steven Tran
329 Reputation
2 Guides authored
UW Tacoma, Team S1-G6, Rose Fall 2018 Member of UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,105
