Keurig B70 Platinum Brewer Handle Replacement
  1. Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: step 1, image 1 of 3 Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: step 1, image 2 of 3 Keurig B70 Platinum Brewer Handle Replacement, Brewer Handle: step 1, image 3 of 3
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Keurig B70 Platinum Brewer Handle Replacement: step 2, image 1 of 2 Keurig B70 Platinum Brewer Handle Replacement: step 2, image 2 of 2
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Keurig B70 Platinum Brewer Handle Replacement: step 3, image 1 of 2 Keurig B70 Platinum Brewer Handle Replacement: step 3, image 2 of 2
    • Lift and pull the black plastic cover away from the Keurig.
  4. Keurig B70 Platinum Brewer Handle Replacement: step 4, image 1 of 1
    • Push the handle back and upward to detach it from the Keurig.
Thu Hoang
217 Reputation
2 Guides authored
UW Tacoma, Team S1-G6, Rose Fall 2018 Member of UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 441
