Keurig B60 Water Gasket Replacement
  1. Keurig B60 Water Gasket Replacement, Water Filter: step 1, image 1 of 2 Keurig B60 Water Gasket Replacement, Water Filter: step 1, image 2 of 2
    • Remove the Water Reservoir Cap and the Water Reservoir from the brewer by simply pulling up and out
  2. Keurig B60 Water Gasket Replacement: step 2, image 1 of 2 Keurig B60 Water Gasket Replacement: step 2, image 2 of 2
    • Remove the three 9.5 mm Phillips #1 screws that secure the small circular screen to the bottom of the water reservoir.
  3. Keurig B60 Water Gasket Replacement: step 3, image 1 of 3 Keurig B60 Water Gasket Replacement: step 3, image 2 of 3 Keurig B60 Water Gasket Replacement: step 3, image 3 of 3
    • This circular screen has a rubber "O"-ring around the base. Use the plastic opening tool to pry off the rubber seal. Replace with undamaged seal.
2 other people completed this guide.
Jake Wynn
830 Reputation
5 Guides authored
Cal Poly, Team 1-7, Maness Spring 2016 Member of Cal Poly, Team 1-7, Maness Spring 2016
CPSU-MANESS-S16S1G7
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 45
All Time: 7,671
