Kensington Hi-Fi Headphones 33137 Speaker Clamp
  1. Kensington Hi-Fi Headphones 33137 Speaker Clamp, Inner Headband Cover: step 1, image 1 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp, Inner Headband Cover: step 1, image 2 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp, Inner Headband Cover: step 1, image 3 of 3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 2, image 1 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 2, image 2 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 2, image 3 of 3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 3, image 1 of 2 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 3, image 2 of 2
    • This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
    • Turn the headphones so that the inner headphone cover is visible.
  4. Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 4, image 1 of 2 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 4, image 2 of 2
    • Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
    • The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • All steps can be followed on both the left or right side of the headphones to remove inner coverings.
  5. Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 5, image 1 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 5, image 2 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 5, image 3 of 3
    • Use the screwdriver to pry the inner headband covering loose.
    • Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
    • Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
  6. Kensington Hi-Fi Headphones 33137 Speaker Clamp, Speaker Clamp: step 6, image 1 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp, Speaker Clamp: step 6, image 2 of 3 Kensington Hi-Fi Headphones 33137 Speaker Clamp, Speaker Clamp: step 6, image 3 of 3
    • Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
    • Pull the speaker clamp so that the metal lifts free of the headband.
  7. Kensington Hi-Fi Headphones 33137 Speaker Clamp: step 7, image 1 of 1
    • Remove the speaker clamp.
    • All steps can be followed on either the left or right arm of the headphones to remove speaker clamps.
Alexis Carr
417 Reputation
4 Guides authored
Clemson, Team 1-3, Benson Spring 2014 Member of Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 305
