Kenmore 80 Series Washer Water Inlet Valve Replacement
  1. Kenmore 80 Series Washer Water Inlet Valve Replacement, Moving the washer: step 1, image 1 of 1
    • Move the washer away from the wall without unplugging any electric outlets or water hoses.
  2. Kenmore 80 Series Washer Water Inlet Valve Replacement, Shut off electricity and water supply: step 2, image 1 of 2 Kenmore 80 Series Washer Water Inlet Valve Replacement, Shut off electricity and water supply: step 2, image 2 of 2
    • Unplug the washer from the electric wall outlet.
    • Turn off the hot and cold water supply valves by rotating the valves in a clockwise rotation.
  3. Kenmore 80 Series Washer Water Inlet Valve Replacement, Disconnect water hoses (hot and cold): step 3, image 1 of 1
    • Use the groove joint pliers to remove the hot and cold water hoses in a counter-clockwise rotation.
    • Place removed hoses in a bucket to catch the leaking residual water.
    • Use a sticky note to distinguish hot and cold hoses if the color-coating metals are not provided.
  4. Kenmore 80 Series Washer Water Inlet Valve Replacement, Move the control panel out of the way: step 4, image 1 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Move the control panel out of the way: step 4, image 2 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Move the control panel out of the way: step 4, image 3 of 3
    • Remove plastic endcaps at either end.
    • Unscrew the screws at either end using the Phillips head screwdriver.
    • Rotate the panel up.
  5. Kenmore 80 Series Washer Water Inlet Valve Replacement, Unplug wire connector: step 5, image 1 of 2 Kenmore 80 Series Washer Water Inlet Valve Replacement, Unplug wire connector: step 5, image 2 of 2
    • Press sides of upper-connector and pull upwards.
  6. Kenmore 80 Series Washer Water Inlet Valve Replacement, Snap out spring clips: step 6, image 1 of 2 Kenmore 80 Series Washer Water Inlet Valve Replacement, Snap out spring clips: step 6, image 2 of 2
    • Pry open the spring clips using the flat head screwdriver.
  7. Kenmore 80 Series Washer Water Inlet Valve Replacement, Tilt cabinet towards you: step 7, image 1 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Tilt cabinet towards you: step 7, image 2 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Tilt cabinet towards you: step 7, image 3 of 3
    • Slide out and remove the shell of the washer.
  8. Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove wire connectors from valve (hot and cold): step 8, image 1 of 2 Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove wire connectors from valve (hot and cold): step 8, image 2 of 2
    • Pull connectors directly towards you.
    • Properly distinguish hot(red) and cold (white) connectors.
  9. Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove mounting screws: step 9, image 1 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove mounting screws: step 9, image 2 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove mounting screws: step 9, image 3 of 3
    • Use the 5/16” nutdriver to unscrew both mounting screws.
  10. Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove clamp from interior water hose: step 10, image 1 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove clamp from interior water hose: step 10, image 2 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Remove clamp from interior water hose: step 10, image 3 of 3
    • Use the groove joint pliers to press clamp and slide down from water hose.
    • Remove valve out from back panel.
    • Remove interior water hose from inlet water valve.
  11. Kenmore 80 Series Washer Water Inlet Valve Replacement, Install new water inlet valve: step 11, image 1 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Install new water inlet valve: step 11, image 2 of 3 Kenmore 80 Series Washer Water Inlet Valve Replacement, Install new water inlet valve: step 11, image 3 of 3
    • Slide the interior water hose over the water inlet valve.
    • Use groove joint pliers to depress the clamp and secure the water hose to the valve.
Nathan Johnson
193 Reputation
1 Guide authored
One Comment
Nice but you did not share the most complicated part. putting the shell back on. its not just simple. corner slots, getting all slots aligned without damaging the inlet dispenser above the tub. then having the front side seat on the frame. i have spent more time and frustration on getting the shell back on verses the entire valve replacement.
Whiskey Piper - Reply
Past 24 Hours: 2
Past 7 Days: 45
Past 30 Days: 217
All Time: 2,589
