Kenmore 400 Washer clutch band Replacement
  1. Kenmore 400 Washer clutch band Replacement, Clutch band: step 1, image 1 of 3 Kenmore 400 Washer clutch band Replacement, Clutch band: step 1, image 2 of 3 Kenmore 400 Washer clutch band Replacement, Clutch band: step 1, image 3 of 3
    • Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
    • Open the lid
    • Remove cap from the agitator by using a flat tip screwdriver or similar.
  2. Kenmore 400 Washer clutch band Replacement: step 2, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 2, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 2, image 3 of 3
    • With the cap removed, a 7/16 hex bolt becomes visible.
    • Use a socket wrench with 4 inch extension to remove the bolt.
    • The agitator bolt measures 5/16 X 1 inches, 24 thread size
  3. Kenmore 400 Washer clutch band Replacement: step 3, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 3, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 3, image 3 of 3
    • With the bolt removed, pull the agitator of the shaft.
    • View of the drum with agitator removed
    • For ease of working on the bottom parts, lay the washer on its side.
  4. Kenmore 400 Washer clutch band Replacement: step 4, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 4, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 4, image 3 of 3
    • Main parts of the assembly include
    • Drain pump
    • Motor
    • Transmission
    • This is a direct drive model. No belts but a motor coupler connects the motor to transmission. Check for any cracks etc.
    • Remove the wiring harness from the motor
  5. Kenmore 400 Washer clutch band Replacement: step 5, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 5, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 5, image 3 of 3
    • Remove the wiring harness from the clip on the transmission
    • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
    • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  6. Kenmore 400 Washer clutch band Replacement: step 6, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 6, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 6, image 3 of 3
    • Pull the drain hose of the pump
    • Remove the tub-to-pump hose the same way
    • Remove the three 1/2inch bolts.
  7. Kenmore 400 Washer clutch band Replacement: step 7, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 7, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 7, image 3 of 3
    • Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head.
    • With the three bolts removed, pull the complete assembly out of the drum
    • With the assembly removed, the clutch is now completely visible.
  8. Kenmore 400 Washer clutch band Replacement: step 8, image 1 of 3 Kenmore 400 Washer clutch band Replacement: step 8, image 2 of 3 Kenmore 400 Washer clutch band Replacement: step 8, image 3 of 3
    • It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced
    • Using a pair of pliers to compress the spring will loosen the clutch band.
    • Lift the clutch band out of the clutch housing
    • Clutch band removed. Replace with model specific part.
11 other people completed this guide.
oldturkey03
782,780 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
549 Guides authored
15 Comments
Would this repair fix a 80 series Kenmore washer with same problem of no high-speed spinning
Larry Simonetta - Reply
Possibly but it depends on what is going on with it. This one spun just sluggish and not „forcefull“ enough. It pretty much stopped spinning with a full load because of the weak clutch
oldturkey03 -
How much do it cost to repair it
Ralph Lingelbach - Reply
The complete repair kit was somewhere between USD $30-$40
oldturkey03 -
I'm a jack of all if I can get it out I can rebuild it im a maintenance man at chicken proscenium plant we got to fixs all of it
Past 24 Hours: 6
Past 7 Days: 67
Past 30 Days: 260
All Time: 29,938
