Karcher Carpet Cleaner 10066730 2014 Breaker Replacement
  1. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the screws securing the front panel: step 1, image 1 of 1
    • Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
    • Use a Phillips screwdriver to remove the six screws securing the front panel.
  2. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Tilt the front panel down: step 2, image 1 of 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Tilt the front panel down: step 2, image 2 of 2
    • Grip the front panel at the top and tilt down to reveal the switch electronics.
    • The front panel will stay attached to the device with the flexible tubing.
  3. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker button cover: step 3, image 1 of 1
    • Use a 16 mm socket to loosen the nut on the breaker button cover.
  4. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement: step 4, image 1 of 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement: step 4, image 2 of 2
    • Remove the breaker button cover.
  5. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker wires: step 5, image 1 of 2 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker wires: step 5, image 2 of 2
    • Separate the breaker from the front panel.
  6. Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: step 6, image 1 of 3 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: step 6, image 2 of 3 Karcher Carpet Cleaner 10066730 2014 Breaker Replacement, Remove the breaker: step 6, image 3 of 3
    • Grip the black wire by its blue connector and pull directly away from the breaker to remove it.
    • Grip the dark blue wire by its blue connector and pull directly away from the breaker to remove it.
    • Make a note of which wire goes where to help during reassembly.
    • Only the breaker remains.
Carsten Frauenheim
116,243 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 426
