Kambrook 600W Power Drive Blender Disassembly
  1. Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: step 1, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: step 1, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: step 1, image 3 of 3
    • Firstly, take off lid by twisting anti-clockwise.
    • Remove the glass jar from the blender base by again twisting anti-clockwise.
  2. Kambrook 600W Power Drive Blender Disassembly: step 2, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 2, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 2, image 3 of 3
    • The blender blade is attached to a base component at the bottom of the blender jar.
    • To remove the blade, simply twist the attachment according to the direction written, in this case, turning anti-clockwise.
    • The blade could be then easily taken out from the jar, if difficulties occur at this stage, simply adjust the blade's angle when removing so.
  3. Kambrook 600W Power Drive Blender Disassembly: step 3, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 3, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 3, image 3 of 3
    • Remove four screws from the base of the blender
    • Take out the ventilation opening from the base. Keep screws aside.
  4. Kambrook 600W Power Drive Blender Disassembly: step 4, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 4, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 4, image 3 of 3
    • The clutch is attached to the bottom of the blender. This can be twisted out directly with hand.
    • The disk attached inside the clutch can be pulled out after the clutch is removed from the blender bottom.
  5. Kambrook 600W Power Drive Blender Disassembly: step 5, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 5, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 5, image 3 of 3
    • This little component is used to stabilise wires. It can be taken out after cutting the wires.
  6. Kambrook 600W Power Drive Blender Disassembly: step 6, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 6, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 6, image 3 of 3
    • Lift out the major electronic part of the blender.
    • Cut off two pieces of wires, then take out the mini light bulb.
    • This is how the blender base should look like at the moment.
  7. Kambrook 600W Power Drive Blender Disassembly: step 7, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 7, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 7, image 3 of 3
    • Unscrew the two screws from both sides of the clasp to detach all component, this includes the motor of the blender
  8. Kambrook 600W Power Drive Blender Disassembly: step 8, image 1 of 3 Kambrook 600W Power Drive Blender Disassembly: step 8, image 2 of 3 Kambrook 600W Power Drive Blender Disassembly: step 8, image 3 of 3
    • Insert wisdom here.
  9. Kambrook 600W Power Drive Blender Disassembly: step 9, image 1 of 2 Kambrook 600W Power Drive Blender Disassembly: step 9, image 2 of 2
    • To take out the back of the of blender speed dial, unscrew two screws that are located opposite each other.
  10. Kambrook 600W Power Drive Blender Disassembly: step 10, image 1 of 2 Kambrook 600W Power Drive Blender Disassembly: step 10, image 2 of 2
    • After taking out the back of the speed dial, the dial will fall out itself.
    • There are three individual pieces that make up the speed dial: the ring, the metal and plastic casting.
  11. Kambrook 600W Power Drive Blender Disassembly: step 11, image 1 of 2 Kambrook 600W Power Drive Blender Disassembly: step 11, image 2 of 2
    • The final disassembly, with all the blender parts and screws, will look like this.
Angel Lin
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 68
All Time: 4,605
