Kailh Silent Brown Switch Lubrication
  1. Kailh Silent Brown Switch Lubrication, Open switch: step 1, image 1 of 2 Kailh Silent Brown Switch Lubrication, Open switch: step 1, image 2 of 2
    • Use the kailh style opener.
    • Press firmly on both sides when lined up correctly.
    • Be careful to not pop off the protection cover, if it does pop off skip to step 10.
  2. Kailh Silent Brown Switch Lubrication, Prepare brush: step 2, image 1 of 1
    • Dip brush in lube.
    • Use lid of the lube to take off most of the lube on the brush
  3. Kailh Silent Brown Switch Lubrication, Lube base: step 3, image 1 of 2 Kailh Silent Brown Switch Lubrication, Lube base: step 3, image 2 of 2
    • Take you brush and twirl it around in the base.
  4. Kailh Silent Brown Switch Lubrication, Lube the stems: step 4, image 1 of 1
    • To preserve tactility only lube the back.
    • Lube in one or two strokes.
  5. Kailh Silent Brown Switch Lubrication, Lube cover: step 5, image 1 of 1
    • Lube the rails on each side of the cover.
  6. Kailh Silent Brown Switch Lubrication, Lube springs: step 6, image 1 of 1
    • Put all the springs in a bag.
    • Add the liquid lube and mix it in with the springs
    • Then put them on a paper towel and separate them.
  7. Kailh Silent Brown Switch Lubrication, Put spring onto base: step 7, image 1 of 2 Kailh Silent Brown Switch Lubrication, Put spring onto base: step 7, image 2 of 2
    • Insert the spring onto the protrusion.
  8. Kailh Silent Brown Switch Lubrication, Put stem into  the cover: step 8, image 1 of 1
    • Insert wisdom here.
  9. Kailh Silent Brown Switch Lubrication, assemble switch: step 9, image 1 of 1
    • When putting it together face the bump of the stem towards the green push rod.
  10. Kailh Silent Brown Switch Lubrication, If protection cover comes off: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to put the green push rod into the position, and then put the protection cover over it.
Ben raef
241 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 44
All Time: 1,268
