KYVOL CYBOVAC E20 Wheel Replacement
  1. KYVOL CYBOVAC E20 Wheel Replacement, Wheel: step 1, image 1 of 1
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  2. KYVOL CYBOVAC E20 Wheel Replacement: step 2, image 1 of 1
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 1 of 3 KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 2 of 3 KYVOL CYBOVAC E20 Wheel Replacement: step 3, image 3 of 3
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
Randall Morgan
359 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Summer 2023 Member of IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 33
All Time: 253
