KYVOL CYBOVAC E20 Wheel Assembly Replacement
  1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: step 1, image 1 of 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: step 1, image 2 of 2
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 2, image 1 of 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 2, image 2 of 2
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 3, image 1 of 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 3, image 2 of 2
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 4, image 1 of 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 4, image 2 of 2
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel: step 5, image 1 of 1
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 6, image 1 of 1
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 7, image 1 of 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 7, image 2 of 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 7, image 3 of 3
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: step 8, image 1 of 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: step 8, image 2 of 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: step 8, image 3 of 3
    • Remove six 10 mm screws from the housing using a Phillips #00 screwdriver.
    • Open the gearbox.
  9. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 9, image 1 of 1
    • Gently remove each gear.
  10. KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 10, image 1 of 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: step 10, image 2 of 2
    • Use a J1 screw driver to remove two 6 mm screws from the gearbox.
Randall Morgan
359 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Summer 2023 Member of IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 161
